- Honor Magic V2 - origami
- Letiltás - hogy is van ez?
Megjelenési dátumot kapott a Conscript
gp Az I. Világháborús horror játék jövő hónapban érkezik.
ma Mármint magukhoz képest, a Stellantis csoport márkáiban használt CMP platformhoz tartozó hajtáslánc optimalizációjának eredménye a mindennapokban is érezhető.
Úgy fest mégis lesz B450-ben Zen 3, így a Renoir is biztosnak tűnik.
Anandetch hírből ez elég fontos. Hogy a Zen 2 alapú Renoirra is igaz e a lenti, az majd kiderül.
As the team weighed your feedback against the technical challenges we face, we decided to change course. As a result, we will enable an upgrade path for B450 and X470 customers that adds support for next-gen AMD Ryzen™ Processors with the “Zen 3” architecture. This decision is very fresh, but here is a first look at how the upgrade path is expected to work for customers of these motherboards.
1. We will develop and enable our motherboard partners with the code to support “Zen 3”-based processors in select beta BIOSes for AMD B450 and X470 motherboards.
2. These optional BIOS updates will disable support for many existing AMD Ryzen™ Desktop Processor models to make the necessary ROM space available.
3. The select beta BIOSes will enable a one-way upgrade path for AMD Ryzen Processors with “Zen 3,” coming later this year. Flashing back to an older BIOS version will not be supported.
4. To reduce the potential for confusion, our intent is to offer BIOS download only to verified customers of 400 Series motherboards who have purchased a new desktop processor with “Zen 3” inside. This will help us ensure that customers have a bootable processor on-hand after the BIOS flash, minimizing the risk a user could get caught in a no-boot situation.
5. Timing and availability of the BIOS updates will vary and may not immediately coincide with the availability of the first “Zen 3”-based processors.
6. This is the final pathway AMD can enable for 400 Series motherboards to add new CPU support. CPU releases beyond “Zen 3” will require a newer motherboard.
7. AMD continues to recommend that customers choose an AMD 500 Series motherboard for the best performance and features with our new CPUs.solfilo
válasz commanDOS #7118 üzenetére
Az egyik gondolom a DIY értékesítésre szánt BOX verzió, 3 év garanciával, a másik feltételezem valami OEM féléknek szánt cucc 1 év garanciával, mégis ez a drágább (csak itt nem írja a terméknév, hogy OEM, de az olcsóbbik típusnál ez szerepel: YD3200C5FHBOX). Más prociból is van ilyen nagy árkülönbséggel ebben a boltban, nem nagyon kell foglalkozni vele, a BOX-ot vedd.
solfilo
válasz E.Kaufmann #7119 üzenetére
Nem láttam, mint mondtak Linusnál a szakik, de az AMD épp most készül MSRP vágásra a Ryzen 9 3900X esetében pl. De persze bármi lehet még később az évben.
AMD Repositions Ryzen 9 3900X at $410 Threatening both i9-10900K and i7-10700K[ Szerkesztve ]
solfilo
válasz paperboy #7126 üzenetére
Hát, a Ryzen 3000 startkor jelzett selective beta bios update needed a B350, X370-nél már előre vetítette, hogy ezzel kb vége a dalnak. Most itt tart a B450/X470. Ez van, így is sokkal jobb a helyzet, mint a túloldalon, vagy akárcsak MSI-nél FM2+ foglalaton.
(Lapom fogadta a Trinity-Richland-Kaveri triót, de a Kaverihez képest újabb steppingnek számító Godavarit már nem, ahhoz ugyanannak a lapnak a V2 verzióját kellett volna venni, de persze Godavari után már nem jött bele semmi. )
solfilo
válasz Peter Kiss #7146 üzenetére
Nekem 2400G, nem szaggat a Youtube.
Edge melyik, a Chromium vagy a régi?
Firefox is csinálja?
Mikor kezdte a szaggatást? Vagy mindig is szaggatott?[ Szerkesztve ]
solfilo
válasz Peter Kiss #7151 üzenetére
Elég fura problémának tűnik, mintha a hardveres gyorsítással lenne gond. Mutatsz egy youtube statot, mellette a Win feladatkezelő teljesítmény fülét?
solfilo
válasz Peter Kiss #7153 üzenetére
Statot úgy értettem, hogy elindítod a youtube videót (linkelem, hátha megnézi egy 3400G tulaj), megy egy kicsit, jobb klikk, statisztika, az kiírja, mennyi az eldobott frame.
Elég fura hiba tényleg, az látszik, hogy megy a hardveres gyorsítás, mert a proci malmozik, a GPU dolgozik.Ilyesmire gondoltam. 2160p-re raktam, 3934 frame-ből nem dobott el egyet se)
solfilo
válasz Peter Kiss #7164 üzenetére
Tippre nem is lesz a másikkal gond, mert te vagy az első, aki ilyen hibáról számol be itt, nem lehet, hogy az egyik 3400G hibás? Bár ha nem mindig csinálja, akkor a hardverhiba talán kizárható.
solfilo
válasz Peter Kiss #7166 üzenetére
Mutatsz linket a videóhoz, hogy ne csak elképzelni tudjuk a hibát?
solfilo
válasz Peter Kiss #7169 üzenetére
Köszi! Elképzelésem nincs mi lehet ez, nem láttam még ilyet. Nála is random jön elő a leírás szerint, tehát nem hardverhiba, de ha meg drivergond lenne, akkor miért nem mindenkinél?
Nekem elfeketedés volt régebben yt közben, de az a 3200MHz RAM miatt volt talán, mert mióta 2933MHz-re raktam, nincs gond.[ Szerkesztve ]
solfilo
válasz Beba Snake #7227 üzenetére
Visszanyal az AMD kavarása, hogy az APU-k el vannak csúsztatva egy gennel, így tiszta káosz az egész.
Zen, 14nm: Ryzen 1000/2000G
Zen+, 12nm: Ryzen 2000/3000G
Zen2, 7nm: Ryzen 3000/4000GAzt már elő sem hozom, hogy Athlon 3000G pl még csak 14nm, Zen, csak hogy teljes legyen a diliház.
solfilo
válasz Albigator #7235 üzenetére
Másik topikban beszéltük , de bemásolom ide is. Kéne lassan Renoirnak egy topic, a kérdés, hogy itt legyen, vagy újat kapjon, mert már Zen2 a procirész?
Igazság szerint el is kéne dönteni, hogy milyen bontásban nyíljanak a Zen-es procik topikjai, architektúra mentén, számozás mentén, vagy van e IGP vagy nincs. Előbb utóbb bonyolítja majd az is, hogy egyszerre lesz a piacon GCN5 és RDNA2 IGP-vel is széria.
1) Zen, Zen+, Zen2, idén befigyel a Zen3 is
2) 1000 (csak Zen), 2000 (Zen és Zen+), 3000 (Zen, Zen+, Zen2), 4000 (Zen2 egyelőre)
3) G vagy nem G
és ezek kombinációi[ Szerkesztve ]
solfilo
Emlékszem, hogy beszéltünk róla, sajnos azóta se történt semmi.
Most ugye van az IGP nélkülieknek architektúránként egy topicja
Summit Ridge
Pinnacle Ridge
Matisse
és a G-s prociknak egy, mert a Zen/Zen+ ill a Vega IGP miatt eléggé hasonlítanak.
Kérdés, hogy a dupla annyi mag, Zen2-re váltás indokol e új topicot a Renoirnak.
Kérdés ez hogyan folytatható, teszem azt lesz egy Renoir topic (Zen2+Vega), ide mondjuk befér a Cézanne (Zen3+Vega), vagy a Van Gogh (Zen2+RDNA2)?De lehet el kell felejteni ezt az IGP és IGP nélkülit, architektúránként haladni, a Matisse (Zen2) topicot kiegészíteni Renoirral, a Zen 3 esetében meg már mehetne rögtön egybe a G-s és a nem G-s vonal, de itt ugye a számozás fog bekavarni.
De persze máshogy is lehet, pl sorozatonként, mint ahogy fentebb írtam, csak akkor meg keverednek az architektúrák, ami Zen/Zen+ szinten nem olyan gáz, de Zen+/Zen2 esetében már igen, mert elég nagy a difi a magok és a rendszerek viselkedése között. Lehet Zen2/Zen3 viszonya is ilyen lesz, a 4000 meg ugye Zen3-mal jön, míg a 4000G még Zen2 csak. Szóval nem tudom.(#7238) libit:
lehet akár így is, valami kell lassan, mert már megjelentek desktopon is, el is fogyott pcx-nél és iponnál a 4+ magos készlet.[ Szerkesztve ]
solfilo
válasz Menotti #7246 üzenetére
Vélhetően elfogyott, ez tartott ki legtovább, a 4650G és a 4750G még előbb eltűnt. Mivel egyelőre csak OEM csatornában értékesítik egyelőre ezen cikk szerint, így elég kevés juthat a DIY piacra. (meglepő is volt, hogy ilyen hamar lett készlet néhány webshopban)
solfilo
Ha nem érdekel az IGP, akkor mindenképp a 3100 legyen sztem, gyorsabb. 3400G "csak" a jó erős IGP miatt érdekes.
solfilo
Ezt a sample-t leszedtem, így megy MPC-HC + default madVR kombóval 2400G-n 1080p monitoron, nem tudom mit kell nézni a statban. A beletekerés okoz röccenést, meg képszétesést egy pillanatra (gondolom ebből jön a dropped frames is), utána megy megint szépen. HDR-t nem tudom, hogy kell ellenőrizni, de hátha jön egy 3400G tulaj és megmondja a frankót.
Amúgy 3400G kicsit jobb prociban, az IGP is okosabb elvileg picit, pl 4K Netflix képes.solfilo
válasz AxBattler #7285 üzenetére
Gondolom eléggé helytálló, ránézve a MSI B550 Mortar támogatási listájára, csak Matisse (3000) és Renoir (4000G) van benne jelenleg. X570 viszi a Picasso-t.
Az ilyen megkötésektől általában felfelé szoktak eltérni, mint pl itt, a B350/X370, Ryzen 3000-et elvileg nem visznek, aztán több lap mégis.[ Szerkesztve ]
solfilo
válasz AxBattler #7288 üzenetére
Olcsóbban ott a B450, ugyanazokat a procikat támogatja, mint az X470, jó VRM meg ezeken is tud lenni.
Valamelyik topicban láttam, hogy 2160p@60Hz-et szeretnél HMDI-n, MSI-ken meg ugye hivatalosan csak HDMI 1.4 van. Libit fórumtárs megnézte anno a B450M Mortar és 2400G párossal, meg tudta hajtani a tv-t 2160p@60Hz-en.
solfilo
válasz Gyuri27 #7290 üzenetére
Fázisokkal nem vagyok képben, miért ilyen fontos, hogy 6 legyen? Utoljára ezt a sheetet néztem, eszerint jópár MSI B450 deszka megfelelő húzott 8 magos Matisse alá, vagy stock 3900X/3950X alá (de más gyártóknál is akadnak ilyen B450 modellek). Aki meg 3400G-t vesz első körben, gondolom ennél többet nem nagyon akar.
solfilo
válasz AxBattler #7298 üzenetére
Rémlik, hogy mintha lenne B450-esekkel is ilyen lista, de persze lehet csak behaluzom már és csak szerettem volna ilyen B450-es listát, mikor lapot vásároltam.
Inkább 3200G, az már viszi a Netflix 4K-t.
A 2200G/2400G-re csak ígérték a PlayReady 3.0-t, de végül nem kaptuk meg.
(mondjuk túlélem az 1080p monitorommal, de akkor is bosszantó)[ Szerkesztve ]
solfilo
Azt az 1,4-1,5-öt nem csak akkor kapja, mikor turbózik? Amúgy nem szoktam ezt figyelgetni, szóval nem tudom nálam mi a helyzet (2+ éves már a gép, 2400G). De mintha rémlene, hogy megfelelő órajel, fesz értékeket nem tud minden kiolvasni, Ryzen Mastert feltetted?
solfilo
válasz AxBattler #7317 üzenetére
Igazából azt nem értem, hogy 2018-2020-ban, mikor már erőlködni kell, hogy csak 1080p tv-t tudjál venni, miért nem default még a HDMI 2.0. Ha tényleg csak spórolásból, hogy kevesebb jogdíjat kelljen fizetni, ezért hivatalosan 1.4, gyakorlatban meg 2.0, akkor még azt mondom oké, de így is elég fura az egész.
solfilo
Pont erről beszélek, elég nehéz manapság tv fronton olyat venni, ami csak 1080p, szóval jó eséllyel egy 2160p masinával zárod a vásárt. Így nem értem, miért nem jár alapból a HDMI 2.0 már évek óta.
A PlayReady 3.0 is lazán le van tojva Raven Ridgnél, hiába igérték be. (Picasso már megkapta szerencsére). Ez kéne a 4K Netflixhez, de hiába vettél multimédiára kihegyezett AMD APU-t 50k-ért (2400G), nem kapsz a feature-ből, minek az.
Persze túlélem, nincs 4K megjelenítő itthon, de akkor is bosszantó ez a hiányosság. Polarisnak megy a dolog, pedig az butább ugye.[ Szerkesztve ]
solfilo
válasz Damateo #7374 üzenetére
Az a legjobb, ami kapható, kb ki van fogyva mindegyik APU, ahogy hirtelen nézem.
20k körül/alatt reális az ára: Athlon 200GE/220GE/240GE/3000G, ezek 2/4-es APU-k.
25-35k körül reális az ára: Ryzen 3 2200G/3200G, ezek 4 mag, 4 szálasak (4/4), előbbi nem tudja a PlayReady 3.0-t, utóbbi elvileg igen (4K Netflixhez kellhet, ha pc hajtaná, nem a tv saját appja)
40-50k körül reális az ára: Ryzen 5 2400G/3400G, ezek 4/8-es APU-k. (előbbi nem tudja, utóbbi tudja a PlayReady 3.0-t)Az újabb Ze2n alapú APU-k júliusban kaphatóak voltak (4350G/4650G/4750G), most ahogy nézem, csak a 4650G van újra, jó borsos áron, hűtő nélkül (ez már 6/12-es).
solfilo
válasz zoner15 #7387 üzenetére
A covid szépen felborította a dolgokat.
A több home office miatt több noti fogyott, így a legtöbb chip oda ment vélhetően ami a desktop alkatrészek árának nem tesz jót (most itt nem releváns, de webkamerából is hiány volt nyáron pl, azoknak is megszaladt akkor az ára), a konzolstart is erősebb lett a vártnál (felértékelődött ugye az otthon szórakozás), így a konzolchipek feltételezem kiszorítják az azonos gyártástechnológián készülő AMD procikat és GPU-kat, így azok kínálata csökkent, ára nőtt. Ez pedig felértékeli a korábbi szériákat (3xxxG), mivel azokra is megnő a kereslet azáltal, hogy az újhoz nem lehet hozzájutni (4xxxG).
És a fentiek mellett ki tudja még milyen tényezők játszanak közre abban, hogy a kínálat nem tud lépést tartani a kereslettel.[ Szerkesztve ]
solfilo
Magam részéről nem tudom, miért szállt el az ára, de nem hiszem, hogy kivezetnék. Ha nem sürgős, várnék picit.
Zen 2 magos utódai már megjelentek amúgy, de csak OEM piacra, így nagy ritkán csorognak le a boltokba:
Ryzen 3 PRO 4350G 4/8 mag-szál
Ryzen 5 PRO 4650G 6/12
Ryzen 7 PRO 4750G 8/16Két boltban 50k körül van a 3400G, nem ismerem ezeket az üzleteket.
solfilo
Milyen összehasonlítást néztél? Tomshardware-nél van összesítés, az alapján picit gyorsabb is a 4650G-ben lévő Vega7, mint a 3400G-ben lévő Vega11.
Ettől még persze a felárat max annak éri meg, aki kihasználja a többleterőt prociban.
Érdemi IGP gyorsulás majd akkor várható, ha már RDNA2 alapú lesz, de ilyenek még nem jelentek meg, a most bejelentett Cezanne is Vega még.Tomiék IGP mérése
összesített eredmények átlag és min fps-ben[ Szerkesztve ]
solfilo
válasz Sweet Lou 6 #7426 üzenetére
Tényleg, rosszul rémlett, most meg már meg se néztem. Köszi!
Anandnál van 4650G eredmény, csak ott meg összesítés nincs, meg hülyén tesztelnek, 360/480p minimum meg 1080p maxon, ultrán, stb, így csak az nem derül ki, hogy real world hogy viszonyulnak egymáshoz az APU-k.Van mondjuk kivétel, 1080p és értelmes fps-ek vannak, nyer is a 4650G a 3400G-vel szemben.
Ellenpélda, nem értem ennek így mi értelme:
360p low (megtudjuk, hogy melyik proci az erősebb, bár a Broadwell-t gondolom az IGP húzza le)
1080p max (megtudjuk, hogy egyik se alkalmas erre a beállításra, de azt nem, hogy mire számíthatnánk mondjuk mediumon)
solfilo
Elég áttekinthetetlen ez nekem, jobb szeretem a konkrét teszteket, mint amiket linkeltem is.
Ahogy nézem, erősen játékfüggő, hogy melyik a gyorsabb. Ezek amúgy notis vagy desktop eredmények?
Az se mindegy, hogy 2400G/3400G Vega11-ről van szó, ahogy a Vega7 is lehet többféle.solfilo
De melyik Vega11 IGP-t tesztelték? A 2400G-ben lévőt? Vagy a 3400G-ben lévőt? Vagy a 2800H-ban lévőt?
Több minden változott amúgy az IGP-ben, nem csak az órajelből jön az előny, jobb a multimédiás blokk is valamivel. A10 kiváltására kb bármelyik min 4/4-es APU jó lehetne, nagy kár, hogy alig kapni valamit, s azt is csak drágán.CES 2020: nagyon nekimegy az Intelnek mobil fronton az AMD
"Az integrált grafikus vezérlő tekintetében marad a Vega architektúra, de nem az a verzió, amely eredetileg készült, hanem a Vega 20 GPU-ban található rendszer továbbfejlesztése. Ezzel lényegében jobb lett az órajel szabályozása, valamint megoldott a 4 és 8 bites integer operációk teljes sebesség melletti kezelése, ami főleg a Microsoft DirectML felületénél jelent előnyt. Mindezek mellett a rendszer megkapta a Navi sorozatú GPU-k parancsprocesszorait, de az úgynevezett priority tunneling funkció nem lett beépítve, ami ennyire kevés multiprocesszor mellett nem feltétlenül jelent problémát. Jó hír viszont a multimédiás blokk megújulása, amit a Renoir SoC APU IGP-je szintén a Navi GPU-któl örökölt meg."solfilo
