- Honor Magic V2 - origami
- 2 nm-en készülhet az Exynos 2600
- Kipróbáltuk a Xiaomi 14 Ultra fotós szettjét
- Netfone
Devolver Direct - Jövő hónapban jön a következő show
gp A nagy nyári összeröffenés alkalmából számos új bejelentésre számíthatunk a kiadótól.
blueye
Antelife:
"about language setting , it need set by yourself ... ...but do not worry , it is easy , if you do not know how to set it after receiving , you can contact us , we will help you"és a telefon oldalán:
"This Android device is designed to function specifically with the current Android OS installed on it. Any alterations such as upgrades, modding with custom ROMs, rooting or flashing the Android device with other firmware will automatically void the device's warranty."
Szépen ellentmondanak önmaguknak.
blueye
JIAYU G4 Android 4.2 Smart Phone MTK6589T Quad Core 2G/32G With 4.7 Inch HD IPS Retina Screen 13MP Camera
Special price is 329.99$(SG Post)ZTE V967S MTK6589 Quad Core 1.2GHz Android 4.2 Dual Sim 5.0 Inch QHD Smart Phone
Special price is 169.99$(10$ discount 113ABED)UMI X2 Smartphone 5.0 Inch 1080P FHD Screen 1G/16G MTK6589T 1.5Ghz Quad Core Android 4.2 - Grey
Special price is 249.99$Lenovo S820 SmartPhone Android4.2 Quad Core 1.2GHz With 4.7 inch HD 3G WCDMA 13.0MP
Special price is 295$Lenovo S750 Smartphone Gorilla Water Proof Android 4.2 Quad Core 1.2GHz With 4.5 inch QHD Dual Sim
Special price is 244$(10$ discount 13aed)iocean X7 Black MTK6589T Quad Core 5.0" IPS Screen Android 4.2.Smartphone
our price is 229.85$(SG Post)Original Lenovo K900 Android 4.2 Intel Dual Core 2.0GHz With 5.5 Inch Full HD 13.0MP
our price is 499$(Nillkin case as gift)ThL W8 Beyond MTK6589T 1.5GHz 5.0 Inch FHD Screen Android 4.2- Gray
Discount price is 224.99$(35$ discount 11mini)ThL W8 Beyond MTK6589T 1.5GHz 5.0 Inch FHD Screen Android 4.2- White
Discount price is 224.99$(35$ discount 11mini)Lenovo A660(green arrive)
Lenovo Lephone A660 MTK6577 dual SIM dual-core waterproof IP67 5MP GPS Smart Phone
our price is 118.5$(root and install mulit-language)Lenovo A830 MTK6589 Quad Core Android 4.2 1.2GHz 5.0 inch QHD 3G WCDMA 8.0MP
Special price is 179.99$ -
blueye
válasz UnConnecteD #36888 üzenetére
Régi trükk
blueye
blueye
A második részre itt találsz választ: kulfoldi_rendelesek_nyomkovetes_stb
blueye
válasz berigazek #37135 üzenetére
Nyomkodd a szöveget, ne a piát a GPS satellites-nél (sokszor leírtuk már).
Egyébként: összefoglaló
blueye
blueye
válasz BullZeye #37268 üzenetére
Én nem kereskedek, egyszerűen 2. telefont kerestem, rátaláltam a topic-ra és így vettem. Aztán megtetszett egy másik ajánlat, megvettem azt. Eladtam az elsőt. Most várom a harmadikat, ha megjön nyilván eladom a másodikat, nem kell három telefon
De amit írsz azzal teljesen egyet tudok érteni. -
blueye
blueye
blueye
blueye
válasz KurtCobain #37551 üzenetére
Akkor már nem, sorry.
blueye
válasz KurtCobain #37557 üzenetére
Túl sokan használtuk a kódot
blueye
válasz CoolBoy323 #37560 üzenetére
Ezekben a 2 év garikban én nem nagyon bíznék:
"Tmallbox.com was registered by on 04 Jun 2012. The website is 1 year old and located on the IP 50.63.76.1"
Ki tudja lesz-e még tmallbox 2 év múlva...
blueye
válasz CoolBoy323 #37639 üzenetére
Ennek te vagy a szakértője, de talán pont te írtad hogy minden telónál más és más.
Igaz ezt írásba nem adják a megérkező telefonnal.
Nem mintha abban hinnék hogy a papírt érvényesíteni lehetne - mondjuk egy magyar bíróságnál.[ Szerkesztve ]
blueye
válasz alázógyík #37649 üzenetére
Írjál majd a topic-jába is
blueye
válasz Oxy.kiraly #38167 üzenetére
Ameikai AT&T T-Mobile függő volt, ki van függetlenítve.
blueye
válasz Atomcsirke #38175 üzenetére
Nálam is OK.
Töröld a cachet!
