OFF beszélgetős topic nyílt, a nem Battlefield 4 témákról kérjük, hogy ott beszélgessetek, ez a téma maradjon meg szakmainak! Cheatek a topikban szintén tiltottak!
Kérlek olvasd el mielőtt kérdezel, köszönjük!
SkyS1gn
Remélem a rohadt balansz patch már...!!!Na nesze neked nagy LÓF!!!
"We've started rolling out a new game update for the PC version of Battlefield 4. Among other items, this update addresses the so called "sound loop crash" that caused the game to freeze. You may experience some downtime while this update is rolling out.
Feb 25 PC Game update notes
-Fix for the so called “sound loop crash” issue that caused the game to freeze
-Fix for an issue that sometimes prevented players from shooting while in the gunner position of a vehicle
-Fix for the headshot icon appearing incorrectly at non-headshot deaths, such as suicide or dying of an explosion
-General stability improvements "Ezzel tökölnek ennyit?
Tech addict, $TSLA and Tesla owner, geek.
SkyS1gn
Veteran b.packot amúgy kik kaptak?
(#37719) VAN der BOSS De miért osztják? Veteran statusz vagy mi?
SkyS1gn
"Mikael Hedberg @slicedlime 18 p
We're running a test for a possible "netcode" fix on this server right now:[link] … - please join and help us test! #BF4"
SkyS1gn
"Hi everyone,
We are aware that some of you have been experiencing some crashing since the patch this morning. Below is a workaround for this problem:
1. Go into your game directory (D:\Origin Games\Battlefield 4, or whatever is the default one)
2. If you have a “user.cfg” file, open it in notepad.
3. Delete the command line “UI.DrawEnable 1”
4. Save the file
5. Start the gameThis file is not automatically created by the game so if you do not have it, you will need to create the user.cfg file and include the line mentioned in step 2. Once created Save the file and try to launch the game. It will mostly likely crash once more. After it does, delete the user.cfg and try again.
Thanks."
Bár az a 3. lépés nem delete akar lenni szerintem hanem insert mivel ahogy írja nincs is ilyen fájl csak ha csinálsz szóval minek lenne benne a nemlévő fileban egy nemlévő parancs
SkyS1gn
Ma este jön Catalyst 14.2 beta, elvileg javítva lesz a Mantle színhiba is.
SkyS1gn
válasz SkyS1gn #37754 üzenetére
Ez is hatalmas update...
R27 Server Update
-Included various server optimizations
-Fix for a server crash that could occur when loading Second Assault maps
-Added a player.onDisconnect RCON event that let’s server owners and anti-cheat notify players why they were disconnected from a server[ Szerkesztve ]
SkyS1gn
SkyS1gn
SkyS1gn
SkyS1gn
Amúgy rájöttem a terrain decoration még mindíg bugos.... nem teljesen lett javítva mikor multkor mondtam, most olyan high mediumon lehet kb... ultrára/highra rakva a multkori patch óta sokkal több a hosszú fű/bokor meg a részlet Paracelen pl, de a sima apró 10-15cm fűtől még kopár a föld így tettem egy próbát az low-ultra-redeploy játékkal és lám full sűrű apró fű is megjelent szóval még mindíg félig bugos ami nem kicsit röhej egy 4 hónapja megjelent játéknál!
SkyS1gn
Egyik patch elött csak a 30mm volt használható, aztán most az alap 20mm jobb a 25 és a 30-nál is!
(#37922) G4ula84 Itt egyből be lett jelentve prémium és a dlc-k így 1 évre sürűsödött be a prémium naptár 1,5 év helyett. a Bf3-as rendszer jobbvolt.
SkyS1gn
SkyS1gn
SkyS1gn
Rubén Santana @antal120 1 hr
DICE Stockholm has confirmed that Dragon's Teeth and Final Stand will be done by DICE LA. These devs made Second Assault
SkyS1gn
Independent BF4 Feedback Survey for March 2014
Tessék kiélni magatokat
SkyS1gn
SkyS1gn
válasz TechArtist #38030 üzenetére
Ez csak egy külsős kérdőív... nem a DICE csinálta, de ha elegen kitöltik akkor elküldik nekik amiből úgyse lesz semmi!
SkyS1gn
válasz blaca83 #38035 üzenetére
Agressivre:
Scout elite, M40 és a GOL, GOL-ra a 6x scope kéne de b. pack item aztán tudok rendes véleményt mondani.//
Stellar Dynamics - A Team Showcase Nem semmi![ Szerkesztve ]
SkyS1gn
Battlelog @battlelog 9 mp
Good news... Platoons for BF4 is now available for everyone Battlelog. Create or join a Platoon today! http://battlelog.battlefield.com/bf4/platoons/
-És tényleg igaz hogy csak prémiumosok, megy a felhábrodás már mindenhol
SkyS1gn
válasz D.Orion #38085 üzenetére
"there is something wrong with the new platoons. we created one, then suddenly a couple of randoms joined, moments later someone unknown to us had become founder. then our founder was made a member, and now finally it has had a name change and new founder. wtf is going on?"
"We're looking into the issue and have closed down access to Platoons for now. Stay tuned for more info!"
Ekkora epic failokat mint amiket ezek összehordanak
SkyS1gn
SkyS1gn
válasz devilinsid3 #38114 üzenetére
Naa.. a szerverre lépés lehetne szerintem külön assingment is
SkyS1gn
- Microsoft Surface Pro 6 12.3" 2736 x 1824/i5 8350u/
- Legjobb ÁR!!!HP EliteBook 640 G9 Ezüst (14" / Intel i5-1235U / 16GB / 512GB SSD / Win 11 Pro)
- HP Probook 340S G7 i5-1035G1/8GB/256SSD/Windows 11
- MSI MAG274QRF-QD QLED Gamer Monitor!27"/2k/165hz/1ms/Freesync-Gsync/Type C/Konzolhoz is/Beszámítás!
- Microsoft Surface Pro 4 12" Touch i5-6300U/8GB/256GB NVME SSD/webcam/2736x1824
- Új! - Garmin Venu 3S - kijelző védő fólia - 18mm Quick Release textil óraszíj
- 18db Pentium Gold processzor (1155,1150)
- Tobii Eye Tracker 5 - Fej és szemkövető egyben
- Intel 6.-gen i5-ös "Játékos PC" - Eladó , Számla - Ready !!
