- Ilyen lesz a CMF Phone 1
- Huawei Watch Fit - hajtás, kartárs!
Olcsó USB WiFi AC adapter
A hátsó raktárból érkezhet a Galaxy S24 FE főkamerája
ma A Samsung nem gondolja újra a kamerarendszert és bejáratott alapokra építkezhet.
Megjelenési dátumot kapott a Conscript
gp Az I. Világháborús horror játék jövő hónapban érkezik.
blattida
Idézet a matousec oldaláról:
" Methodology and rules
Installation and configurationThe tested products are installed on Windows XP Service Pack 3 with Internet Explorer 8 set as the default browser. The products are configured to their highest usable security settings and tested with this configuration only. We define the highest security settings as settings that the user is able to set without advanced knowledge of the operating system. This means that the user, with the skills and knowledge we assume, is able to go through all forms of the graphic user interface of the product and enable or disable or choose among several therein given options, but is not able to think out names of devices, directories, files, registry entries etc. to add to some table of protected objects manually, not even if such a configuration is suggested on the product's support forum or website.
Testing levels
There are several testing levels in Proactive Security Challenge. Each level contains a selected set of tests and it also contains a score limit that is necessary to pass this level. All products are tested with the level 1 set of tests. Those products that reach the score limit of level 1 and thus pass this level will be tested in level 2 and so on until they reach the highest level or until they fail a limit of some level."
Tehát nem alapbeállításokkal tesztelnek. Az avira tűzfala ebből a szempontból nagyon gyönge...
Gauranga! हरे कृष्ण हरे कृष्ण कृष्ण कृष्ण हरे हरे || हरे रामा हरे रामा रामा रामा हरे हरे||
blattida
Mielőtt sokan azt hinnék, hogy a szoftveres tűzfalak ugyanolyanok és ugyanúgy megfelelnek a "célnak", azt írjuk le, hogy annak a célnak felel meg a mai összes szoftveres tűzfal, hogy figyelje a kimenő és bejövő forgalmat. Az már egy másik kérdés, hogy nem mindegy, hogy egy rövidlátó nagyanyó, egy barátnő, egy nagyítót használó gyerek vagy egy elektronmikroszkóp optikai képességével rendelkezik e az adott tűzfal. Ugyanis a matousec féle leak tesztet a két első példám simán elbukja 0 ponttal, és a harmadik példám is elvérzik néhány pontocskával. Az avira tűzfala pedig a harmadik csoportba tartozik, sok egyéb társával együtt.
Ha kellő mélységben képes vizsgálni egy tűzfal a hálózati forgalmat és az alkalmazások közötti interakciót, akkor gyakorlatilag mindent ki lehet vele szűrni, csak tudni kell használni...és attól, hogy sokan nem képesek erre, még van létjogosultsága.
Abszolút nem fölösleges a matousec féle teszt, ámbár az igaz, hogy nem az átlag felhasználóknak szól, de ezt nem is mondta senki.Gauranga! हरे कृष्ण हरे कृष्ण कृष्ण कृष्ण हरे हरे || हरे रामा हरे रामा रामा रामा हरे हरे||
blattida
Mivel mindkettő a kellő felismerésűek klubjába tartozik, más jellemzőket kell figyelembe venni a kiválasztásnál. Éles helyzetben, a gyakorlatban, a vad internet sűrű hálózatán bizony az avast alulmarad az avira-val szemben is, egyszerűen nem véd meg kellően a fertőzésektől és az eltávolító képessége sem a legjobb. Az átlagos júzer internetes szokásai és ismeretei nem elegendőek az avast mellett, ha tiszta akar maradni.
A tapasztalt és edzett "netbuziknak" talán elégséges, de azok kevesen vannak, ráadásul az avast böszme lassú és nem egy kisétvágyú jószág...Gauranga! हरे कृष्ण हरे कृष्ण कृष्ण कृष्ण हरे हरे || हरे रामा हरे रामा रामा रामा हरे हरे||
blattida
válasz polonic #16098 üzenetére
Ez gyakran előfordul a részükről. Amúgy hat hónapos licencet már régóta nem lehet szerezni, betyarr jól írta.
malware: CIS
Szerintem éppen tesztelt programokat nem kellene írni, mert félrevezető.
blattida
1. Nem rossz, de van jobb is.
2. A semmihez képest igen, egyébként nem igazán.
3. A tűzfal nem túl erős, az antispam modulja sem a legjobb.
4. Igen. Antispyware-t legalább.
5. Ez nem legális, ilyet ne kérj a fórumon, mert kizárnak!Gauranga! हरे कृष्ण हरे कृष्ण कृष्ण कृष्ण हरे हरे || हरे रामा हरे रामा रामा रामा हरे हरे||
blattida
válasz Fire/SOUL/CD #16293 üzenetére
A magam részérő már évekkel ezelőtt átestem ezen a teszteljünk ismeretlen av-ket dolgon. Az a tapasztalat, hogy nem véletlenül ismeretlenek.
A CAT Quick Heal nem ebbe a tárgykörbe tartozik, régi indiai motorosok,a VB-n is évek óta szerepelnek, nem is rossz a cucc, volt szerencsém hozzá párszor az évek alatt, legutoljára nagyjából egy hónappal ezelőtt, de nem is a legjobbak közé tartozik. A víruscsomagokon úgy 95%-os felismerést produkált. A kezelőfelülete egyszerű, nem rendelkezik túl sok beállítási lehetőséggel, a keresési sebessége és a fogyasztása átlagos.
blattida
válasz BigManus #16300 üzenetére
Mint írtam, egy hónapja teszteltem, akkor 95% volt az arány.
Nem telepítettem a tűzfalát, mert tudtam, hogy milyen.
Nálam galibákat nem okozott, a frissítése is lassú volt, de nem ennyire.Fire: A Bullguard gyakorlatilag Bitdefender, tehát annyira nem lehet rossz.
Én próbáltam a 2009-es Bitdefender AV-t, hát, ez már nem nekem való, az új irányzat a tényleg tudatlan felhasználókat célozza meg, szinte nulla beállítási lehetőséggel, automatizált az egész, gyűlölöm, ha kihagynak az irányításból a gépemen...Gauranga! हरे कृष्ण हरे कृष्ण कृष्ण कृष्ण हरे हरे || हरे रामा हरे रामा रामा रामा हरे हरे||
blattida
válasz Fire/SOUL/CD #16311 üzenetére
Szerinted nem kattintottam rá?! Például az AV modul beállíthatósága lófasz, már elnézést! A 2008-ast sokkal jobban lehetett konfigurálni.
A többi rész pedig annyira állítgatható, amennyire minimum elvárható.
Az ilyen apró mütyűrök kezelése nálam nem számít annak, sem a pipák száma önmagában.[ Szerkesztve ]
blattida
válasz Fire/SOUL/CD #16315 üzenetére
Bocs, kicsit erősen fogalmaztam. Tehát: be lehet állítgatni az AV-t is, de körülményesen, ráadásul nálam a környezeti kereső nem funkcionált, plusz, rengeteg alkalmazásom használhatatlan lett memória hozzáférési hiba miatt.
A 2008-as emlékeim szerint egyszerűbben és jobban konfigurálható volt, nagyobb szabadság mellett, nem beszélve a régebbiekről.
Igaz viszont, hogy a téves riasztásai csökkentek, csilivilibb lett a GUI-ja és tovább javult a felismerési aránya.
De nekem nem jön be.Gauranga! हरे कृष्ण हरे कृष्ण कृष्ण कृष्ण हरे हरे || हरे रामा हरे रामा रामा रामा हरे हरे||
blattida
válasz Fire/SOUL/CD #16320 üzenetére
Oké, ha ezt szeretnéd : DrWeb IS, e-Scan IS, Rising IS.
blattida
válasz Fire/SOUL/CD #16325 üzenetére
Jah...hogy neked mindenképp kell tűzfal..a ruszkiknál nincs tűzfal, sajnos...
blattida
válasz Fire/SOUL/CD #16327 üzenetére
Maradjunk annyiban, hogy szokott, ráadásul nálam még fent van az escan IS és nincs gond vele...
A doktor nem jött be...Gauranga! हरे कृष्ण हरे कृष्ण कृष्ण कृष्ण हरे हरे || हरे रामा हरे रामा रामा रामा हरे हरे||
blattida
válasz BigManus #16328 üzenetére
Én többek között ezért nem használom már egy ideje az avira-t.
Már megint rossz irányba mennek.Fire: Akkor tégy egy próbát a KIS-sel(Kingsoft Internet Security)! Abban van minden.
blattida
válasz blattida #16336 üzenetére
A noname nem azt jelenti, hogy kevésbé ismert, hanem azt, hogy szar, gagyi, hamis, utánzat és mindezek mellett olcsó. Sokmilliós ügyfélkörrel, évtizedes multal rendelkező cégeket igen csak botor dolog lenonémezni.
Tehát szerintetek egy Glashütte noname, egy TVR noname, Kubrick noname, egy Shimano noname, egy Audio Note noname, egy Hannah noname...
Ébredjünk már föl ebből a nagy magyar sötétségből, emberek!Gauranga! हरे कृष्ण हरे कृष्ण कृष्ण कृष्ण हरे हरे || हरे रामा हरे रामा रामा रामा हरे हरे||
blattida
válasz blattida #16339 üzenetére
Ez, elvileg, egy szakmai topik. Az ilyen megjegyzések csak az egyébként is alacsony színvonalat viszik valahová a névtelen béka segge alá...Nem csodálom, hogy nem sok régi motoros maradt.
blattida
válasz Fire/SOUL/CD #16335 üzenetére
Na, hogy tetszik a lájonsztrong Rising IS?
Milyen a cica?Gauranga! हरे कृष्ण हरे कृष्ण कृष्ण कृष्ण हरे हरे || हरे रामा हरे रामा रामा रामा हरे हरे||
blattida
válasz Fire/SOUL/CD #16342 üzenetére
Ha már noném kategória, akkor tesztelhetnéd a GDATA IS-t is, hiszen sokan ki se próbálják és megoszthatnád a tapasztalataid. A Comodo IS-t csak azért nem ajánlom, mert bár irtózatosan noném, én már megtettem. Kíváncsian várom az eredményt.
blattida
válasz BigManus #16351 üzenetére
Mivel négymotoros, ezért nem meglepő a felismerési aránya.
A kezelőfelülete is normálisnak tűnik. Viszont híres a magas fals pozitív arányáról, ami multiendzsin mivolta miatt nem szinte megszokott.
Tényleges fogyasztási adatokat és keresési időket is meg tudsz adni?Gauranga! हरे कृष्ण हरे कृष्ण कृष्ण कृष्ण हरे हरे || हरे रामा हरे रामा रामा रामा हरे हरे||
blattida
Valósidejű védelmek tesztje 22 mintával: eredmények
Ekkora minta alapján kicsit félrevezető, de nem teljesen haszontalan.Gauranga! हरे कृष्ण हरे कृष्ण कृष्ण कृष्ण हरे हरे || हरे रामा हरे रामा रामा रामा हरे हरे||
blattida
A titkosításos védelmi részre vonatkozó mendemondák igazak, de nálam például a teszteken nem szerepelt túl fényesen, mármint az antimalware modulja.
Keveset fogyaszt és gyors, de nem lehet túlságosan konfigurálni, a GUI-ja pedig sokaknak nem jönne be a kiskatonával és a játékos kidolgozásával...Gauranga! हरे कृष्ण हरे कृष्ण कृष्ण कृष्ण हरे हरे || हरे रामा हरे रामा रामा रामा हरे हरे||
blattida
válasz Greenebola #16384 üzenetére
Comodo tűzfallal jól elvan az avira a 7-esen is.
blattida
válasz SG3rg0 #16404 üzenetére
A Panda valaha szerepelt a VB-n, de kiszálltak. Jelenleg ők is fölöslegesnek tartják, csakúgy, mint sok más cég, mert mára elavulttá vált és nem alkalmas a valós képességek meghatározására.
Többek között ezek a cégek alapították illetve hozták létre az AMTSO szövetséget, a tesztelési metodikák egységesítése miatt.
Bővebben itt.Gauranga! हरे कृष्ण हरे कृष्ण कृष्ण कृष्ण हरे हरे || हरे रामा हरे रामा रामा रामा हरे हरे||
blattida
válasz Fire/SOUL/CD #16672 üzenetére
Ha tartani tudják a menetrendet, akkor év végén megjelenik a 4-es béta, de a végleges szinte biztos, hogy jövő év elején...
blattida
válasz Fire/SOUL/CD #16676 üzenetére
Én nem, mivel nem használok 7-est, de sokan mások igen, és a 32bites verzió gond nélkül fut, a 64-es kicsit problémásabb, ám úgy tűnik a fórumukról is, hogy tulajdonképpen az is fennakadások nélkül üzemel, természetesen hivatalos 7-es támogatás nélkül.
blattida
Tessék gyerekek, itt van az avast 5 első bétája, jó étvágyat hozzá!
blattida
válasz csaba1203 #16805 üzenetére
Nálam futott, de alapvetően nem bugos, hanem sok funkció még nem elérhető, illetve hiányos ezen a téren. De ez nem egy váratlan dolog, hiszen ez az első publikus béta verzió, lesz még sok a hivatalos kiadásig, ahogy azt az alwil-tól már megszokhattuk...
blattida
válasz Fire/SOUL/CD #16912 üzenetére
Fire, azt azért kijelenthetjük, hogy az az av a legjobb, amelyik a legtöbb mintát ismeri és/vagy felismeri, valamint el is tudja távolítani, ez tény. Tesztelni pedig csak ismert mintán lehet egzakt módon, mert a heurisztikus felismerés soha nem lesz 100%. Ezért is terjed a virtualizáció és a cloud alapú felismerés és kártevőkezelés.
A régóta ismert és elismert av-k közül szinte mindegy, melyiket választja a júzer, mert nagyjából ugyanarra képesek védelmi szempontból, ezért maradnak az egyéb jellemzők, melyek alapján dönteni lehet valamelyik mellett, és ezért használnak sokan sokfélét.Az már egy másik kérdés, hogy a csicsa és a felszín ne élvezzen prioritást a teljesítménnyel szemben és a természetesen mindig ferdítő, tódító reklámoknak sem kellene gondolkodás nélkül bedőlni.
A neten keringő és jelen lévő "tesztek" nagy része nem teszt, ezt mindnyájan tudjuk, de a művelt felhasználók jelentős többsége nem.
Vagyunk páran, akik szélmalomharcot folytatunk, akik próbáljuk felnyitni a szemeket, de ez nagyon lassú folyamat és bukás lesz a vége...Gauranga! हरे कृष्ण हरे कृष्ण कृष्ण कृष्ण हरे हरे || हरे रामा हरे रामा रामा रामा हरे हरे||
blattida
válasz Fire/SOUL/CD #16934 üzenetére
Fire, csak jelzem, hogy a 2010-es Bitdefender sokkal jobban tetszik az elődjénél, minden szempontból, kezelhetőbb, jobban használható, gyorsabb...
KIS/KAV-re/ra átváltva: tényleg hatékony jószág, de állat módon háklis, mint mindig is volt, ráadásul, bár tudom, hogy ez a legutolsó szempont, számomra gyomorforgató a GUI-ja, de komolyan(az a ledlámpa dizájn, meg a mozduló polipkarok...)
blattida
válasz Fire/SOUL/CD #16944 üzenetére
Háklis alatt azt, hogy olyan, mint Máris szomszéd, csak magát szereti, mindenki más menjen a picsába...
Webdokit próbáltam, minimalista, a szegény rokon, az orosz vidék megtanítja az embert arra, tisztelje az egyszerűséget.
Amúgy Returnil-ből a legfrissebbet(.4888.Beta 8) használod? Csak a KIS miatt kérdezem.
- A Samsung elkezdte árulni új Micro LED tévéit
- Gyúrósok ide!
- Nők, nőügyek (18+)
- Aliexpress tapasztalatok
- Milyen asztali médialejátszót?
