- Júliustól kötelező biztosítást kell fizetni egyes rollerek után is!
- Ilyen lesz a CMF Phone 1
- KuKirin G4 - a sebesség ára
Vírusirtó Topic 2019
ƵøŁĭ
válasz Ninja Chick. #18081 üzenetére
Mivel IS komplett védelmet add fölösleges mást felrakni mellé de ha "paranoid user" kategóriába tartozol akkor "esetleg" kingsoft termék vagy WSA szóba jöhet. Kingsoft termék telepítése mellett döntesz figyelj a False találatokra ,mert hajlamos nagyon erre .
(ง'̀-'́)ง(ง'̀-'́)ง
ƵøŁĭ
ƵøŁĭ
Emsisoft Anti-Malware 7.0.0.21
Added support of network share scanning.
Improved Windows 8 compatibility.
Internal enhancements for Enterprise Console support.
Service restart behavior changed as required by Microsoft for certification.
Scheduler bug that occured on midnight actions – fixed.
Minor registration key input box problem – fixed.
Bug in reloading of specific imported settings – fixed.
Occasional application crash when clicking menu items – fixed.
Initial delay for missed scheduled scans or updates was increased to up to 1 minute.
Risk level rating of malware improved.
Bug when submitting custom host rules – fixed.(ง'̀-'́)ง(ง'̀-'́)ง
ƵøŁĭ
Bitdefender 16.28.0.1789
Updates + fixes:
- Removed shutdown notification when disinfecting;
- On Access events for network files were changed;
- Vulnerability wizard displays outdated latest version for supported apps;
- Display percent of overall progress next to progress bar;
- Integrated new On Access driver;
- Disinfection for network files follow different actions - New;(ง'̀-'́)ง(ง'̀-'́)ง
ƵøŁĭ
IMF IObit Malware Fighter 2 Beta 1.0
Changelog:
+ Improved engine with more powerful removing ability, but less resource consuming
+ New generation of real-time protection technology protects your PC in a quiet and intelligent way
+ New"Smart One-Stop Solution" helps you fix problems with one click
+ Brand-New UI, easy and crisp
[link]AVAST 8 R2 beta (8.0.1484)
This program update contains the following major features:
* SecureLine - is a paid VPN service that both secures and anonymizes your internet connection on public or "open" (unsecured) Wi-Fi. Nobody can see who you are or what you are doing on the internet.
Please be patient, this feature will be unblock for your test soon :-)
* Screen readers compatibility
* Software Updater improvements (including a way to turn off Software Update persistently)
* Shredder tool is showing a progress now
* Improved stability & performance
* Fixed glitches in UI
[link]HitmanPro 3.7.3 Build 192 BETA
Changelog:
ADDED: Removal of child pornography images dropped by Urausy ransomware.
ADDED: Detection of zero-day Urausy ransomware through forensic file clustering.
ADDED: Kickstart hardening to protect HitmanPro processes from Winwebsec malware family.
Use Kickstart against Disk Antivirus Professional, AVASoft Antivirus Professional or other rogue antiviruses.
IMPROVED: Forensic file clustering speed.
IMPROVED: Reduced memory usage during forensic file clustering.
IMPROVED: Processing of registry key values.
FIXED: On some BIOSes, when booting with Kickstart, Windows loader would hang with either frozen screen or blinking cursor.
UPDATED: Kickstart Bootstrap loader 2.1.
UPDATED: Embedded white lists.
[link]WSA v8.0.2.127
Improved
Agent shutdown speed
Behavior logging in WIndows Event Logs
Identity Shield functionality on Windows Server 2008
Kernel keylogger protection
Migration process for Prevx users to SecureAnywhere
Added
A registry value of type DWORD named NoStatistics under HKCU\Software\WRData which, when set to 1, disables the behavior statistics on the status screen
Fixed
An issue with changed settings and local database data on shutdown
Compatiblity with Jeeves GARP software
Identifying cloud managed configuration settings
Other
Minor UI changes
[link][ Szerkesztve ]
(ง'̀-'́)ง(ง'̀-'́)ง
ƵøŁĭ
válasz olivera88 #18600 üzenetére
Nem, de valószínűleg hamarosan jön egy kis Update hozzá .
G-Data 2014 termékek , hivatalos oldalon áprilisban lesznek elérhetők.
"The generation 2014 of G Data solution for private users convinces with new user interface, improved performance, and the new, proprietary active hybrid protection "CloseGap". It takes over the tasks of the second engine and in addition it provides extra security with faster, more efficient scanning technology."[ Szerkesztve ]
(ง'̀-'́)ง(ง'̀-'́)ง
ƵøŁĭ
Gondoltam meglessem mennyire hatékony a legújabb béta build ,ezért is gyorsan összeszedtem 20 db mintát.
Beállítási lehetőségek szegényesek,maradtak az alapon,kötelező frissítést elvégeztem.
Nézzük meg a hatékonyságot.
Viszonyítás képen egy EAM vizsgálatot futtattam.
(ง'̀-'́)ง(ง'̀-'́)ง
ƵøŁĭ
Megújult az AVG oldala, nem tudom ki figyelte de én most vettem észre .
(#18629) gyuri2008
Toolbart valószínűleg véletlenül telepítetted fel valamelyik program mellett . Babylon közismert toolbar . Lényegében hatásos védelem mellett legyen az Kaspersky (fizetős) vagy AVG (ingyenes) ,hamar be lehet szerezni ezt a hívatlan vendéget. Egyes vírusirtók telepítésének előkészületei alatt be tudjuk állítani manuálisan , mint pl. ESET-nél "kéretlen alkalmazások keresése "mellyel már letöltés közben észlelni tudjuk az esetleges nem kívánatos dolgokat pl. ask/bablyon toolbar.
Egy picit jobban oda kell figyelni és ezek a dolgok elkerülhetők. AVG ha eddig tünetmentesen viselkedett ne váltsd le ,csak szokásaidat a biztonság kedvéért jobban felügyeld. Adott termékkel való elégedetlenség során első lépésben a hivatalos oldalról tölts le egy eltávolító programot s ezután megfelelő (registry) tisztítást hajts végre.Következő lépésben a gép paramétereihez igazodva ,gépnek kellemes vírusirtót kell választani. Ha erős géped van próbálkozhatsz fizetős TOP kategóriás termékekkel (kinek-mi a TOP),hivatalos tesztekre hivatkozva ezek a termékek Kaspersky,Bitdefender,F-Secure,Norton,Trustport,G-Data. Ingyenes megoldásokat sem szabad kihagyni , mint pl. COMODO,Avast,Avira és stb. Jó választást és további szép napot.(ง'̀-'́)ง(ง'̀-'́)ง
ƵøŁĭ
Webroot Av-Comparatives-en:
Számomra igen kellemes termék ,gépen szinte észrevehetetlen , sose volt vele bajom.
(ง'̀-'́)ง(ง'̀-'́)ง
ƵøŁĭ
Hitman Pro 3.7.3 - Build 193
•IMPROVED: Detection of zero-day Urausy ransomware through forensic file clustering.
•FIXED: HitmanPro stopped working when it encountered a particular forensic cluster.
•UPDATED: Embedded white lists.Na fiúk jövőhét péntekig búcsúzom, kis érettségi + szakmai országos döntő .
(ง'̀-'́)ง(ง'̀-'́)ง
ƵøŁĭ
F-secure Client Security-t kulcs nélkül nem tudom felrakni ,aki tud PM .
(ง'̀-'́)ง(ง'̀-'́)ง
ƵøŁĭ
Mintaszám: 279
F-Secure Client Security 10.0
Detektálás: 87,81%
Kihagyott mintaszám:
Maradék futtatva, MBAM-al végzett ellenőrzés eredménye:
Megjegyzés:
279 minta ,mellyek nem mindegyike különbözik , ennyi idő alatt csak ilyen sikerült ,muszáj volt sietnem "fáj" a fogam.
(ง'̀-'́)ง(ง'̀-'́)ง
ƵøŁĭ
Az alábbi termékek küzöl válasszatok 1-et , még egy kis tesztet megcsinálok ,mert már elegem van a számolásból;tanulásból: TrendMicro,Vipre,FortiClient,Unthreat,Norton,Quickheal.
(ง'̀-'́)ง(ง'̀-'́)ง
ƵøŁĭ
Na megjöttem országot átútazva ,országos döntőt megírva,szóbelizve .
(ง'̀-'́)ง(ง'̀-'́)ง
ƵøŁĭ
ƵøŁĭ
Fiúk 5. lettem Országos Döntőn .
(ง'̀-'́)ง(ง'̀-'́)ง
ƵøŁĭ
Erre majd jövőre kerül sor , most csak +100 pontot kapok .
Eközben új build COMODO-nál .
What's new in 6.1.275152.2801?NEW! Drag n Drop support in rule editors
NEW! View Connections dialog which shows active connections without having to install Killswitch
NEW! Ability to exclude files while restoring from quarantine
There are over 200 bug fixes in this release. Below are the selected few:
FIXED! cmdagent.exe consumes 100% FIXED! CPU when the size of cache is big enough
FIXED! Sandboxed Google Chrome does not open Web pages if CIS and Bitdefender installed
FIXED! Matousec Fileacc1 test fails
FIXED! Malware can load drivers under certain circumstances bypassing the protection
FIXED! 100% CPU consumption while running certain .jar files real-time
FIXED! In Win8 x86, BSOD while scanning with CCE
FIXED! Online videos don’t display correctly in kiosk Dragon when full screen
FIXED! BSOD From Running Iobit Advanced SystemCare
FIXED! Sandboxed malware causes BSOD(ง'̀-'́)ง(ง'̀-'́)ง
ƵøŁĭ
válasz Black Plague #19071 üzenetére
Gondolom idővel kerülnek elő a problémák, melyeket megfelelő szakemberek javítanak idővel . Valószínűleg a felhasználók nyomására jelent meg viszonylag hamar. Nem csak nála van sok bug , hanem pl. avastnál is előfordul és még sorolhatnám . Lényeg idővel javítanak mindent ,az meg evidens hibátlan termék nincs .
(ง'̀-'́)ง(ง'̀-'́)ง
ƵøŁĭ
Hi everybody!
G-Data esetében 2013-as termékről programon belül lehet-e frissíteni a 2014-es verzióra? Ötlett onnan származik ,hogy található még mindig működőképes 180napos promó ,melynek kulcsát 2013as verzió elfogadja ,de a 2014-es nem .
(ง'̀-'́)ง(ง'̀-'́)ง
ƵøŁĭ
válasz King Unique #19093 üzenetére
Egyáltalán nem lassít ,2014 verzióknál - 30% gépterhelés érzékelhető .
(ง'̀-'́)ง(ง'̀-'́)ง
ƵøŁĭ
válasz King Unique #19103 üzenetére
Észrevehetően ( 30%)-al kevésbé terheli a rendszert , gyors bootolás;scan .
PC Tools security portfolio to be retired on May 18, 2013
Symantec will retire the PC Tools Security portfolio (PC Tools Internet Security, Spyware Doctor and Spyware Doctor with Antivirus) on May 18, 2013.
This activity will not impact PC Tools Utilities products. We are retiring the PC Tools Security portfolio as we focus on streamlining our product range to provide fewer, better solutions for our customers. As an alternative to your PC Tools Security solution, Symantec recommends the award-winning, new Norton Internet Security. It provides you with powerful internet protection, no matter where you go or what you do online – and we have special offers available to our existing PC Tools Security customers.
(ง'̀-'́)ง(ง'̀-'́)ง
ƵøŁĭ
válasz King Unique #19105 üzenetére
Érdemes? Ilyen kérdésre válaszolni szubjektív , kinek mi a véleményre róla . Mindenestre ha a Kaspersky probléma mentesen fut , nem érdemes váltani . Annyiban különbözik az F-Securetől ,hogy részletesebb beállítási lehetőségei vannak ,további információt a G-Dataról a hivatalos oldalukon megtalálsz , Windows 8 kompatibilis .
(ง'̀-'́)ง(ง'̀-'́)ง
ƵøŁĭ
G-Data support de rendes , július 15.-ig adott kulcsot , na ezt valamivel viszonzom .
(ง'̀-'́)ง(ง'̀-'́)ง
ƵøŁĭ
válasz King Unique #19111 üzenetére
Igen csak én kaptam,köszi . Nem ilyen téren tanulok hanem környezetvédelem-vízgazdálkodási technikus vagyok/leszek , aztán mérnök .
(ง'̀-'́)ง(ง'̀-'́)ง
ƵøŁĭ
(2013-04-25) Baidu Antivirus 3.2.1.27892
IMPROVED
Enhance the scan ability with latest virus database
Optimized the install experienceFIXED
Fixed the crash problem in some circumstances
Fixed the delay of update of Avira virus database(ง'̀-'́)ง(ง'̀-'́)ง
ƵøŁĭ
Symantec Declares On-Demand Antivirus Tests "Misleading"
[link](ง'̀-'́)ง(ง'̀-'́)ง
● TILOS a warez!
● Vírusos, vagy egyéb kártevőt tartalmazó linkek a topikban való elhelyezésére vonatkozó szabály:
Tilos a topikban bármilyen vírusos vagy lehetséges vírusos kártevő link elhelyezése.
Az ilyen linkek megosztása csak privátban, PH tagok számára osztható meg.
Ellenkező esetben a hozzászólás törölve lesz.
- Vezetékes FEJhallgatók
- Az Xbox Series X|S konzolnak három új verziója jön idén
- Tippmix
- Milyen TV-t vegyek?
- EAFC 24
- Skoda, VW, Audi, Seat topik
