Ez a topik a World of Warcraft világát érintő kérdésekkel, történetekkel és beszámolókkal foglalkozik.
►Hivatalos rendszerkövetelmények WoW-hoz◄
►Blizzard által támogatott videokártyák listája◄
Prohardveres, Blizzard in game Community
WoW Token goldárfolyama
Wolverine
válasz -conrad- #9283 üzenetére
Buffed 15k hp-m van manapság maciban, armor 15-17k körül... ha a skillen múlik, akkor lehet, hogy bajok lesznek
(ja, a földi mountok sem érdekelnek )ui: b verzió: inkább dps-elek és Pola tankolhat
"I'm the best there is at what I do, but what I do best isn't very nice." (Wolverine) / "Hello, I'm the Doctor. Basically... run." (a 11. Doktor)
Wolverine
válasz -conrad- #9286 üzenetére
Kivenném én, ha exalted lennék de addig még van vagy 15k repum. (köztudottan nem járok instázni, ha nincs kedvem. általában nincs.) Staff of Beasts még a tankfegyverem
Wolverine
válasz -conrad- #9306 üzenetére
Anzu
Anzu the Raven God is a summonable boss in the Sethekk Halls of Auchindoun (on Heroic difficulty only). Summoning and killing Anzu allows a druid to complete the Epic Flight Form quest. To summon Anzu, a druid who either is currently on or has already completed said quest must use the [Essence-Infused Moonstone].
"Anzud" is a mythological eagle from Akkadian mythology.
Anzu also is Japanese for "apricot".Attacks and abilities
* Anzu has around 230,000 health.
* Spell Bomb - 8 second curse, burning 2000 mana and deals 1000 damage if a player affected by it casts a spell; Anzu whispers the player affected by the debuff, effectively warning of the effect. It is very important that casters take note of when they have this debuff on them. If you continue to cast whilst this debuff is on you, it will very probably result in a party wipe. If you are unlucky and your druid is repeatedly given this debuff, you will probably find it very difficult to complete this fight. Note: A druid or mage with this debuff is able to safely cast Remove Curse/Remove Lesser Curse on him/herself to remove it and will not take the damage.
* Cyclone of Feathers - Targets a random party member (minus tank) and puts them in a cyclone for 6 seconds. Considered a magic effect, but the debuff also makes you immune for normal dispels. Can be dispelled with Mass Dispel. This ability has a cast bar and can (and should) be interrupted.
* Paralyzing Screech - A 6 second AoE stun on the entire group. Has a 5 second cast time but is not interruptible in any way. It is recommended to place heal over time spells and shields on the tank when you see the cast. Cannot be outranged (100 yard range).
* Banish/Spawn Birds - At 66% then 33% he will banish himself and spawn non elite crows, Broods of Anzu, with about 14k health. The crows do around 700 damage on cloth (around 300 with the Hawk Spirit up) and can be crowd-controlled.Bird statues
When Anzu is summoned, three friendly NPC birds appear as well. Casting a druid HoT on the birds will awaken them for the HoT's duration, and will provide the following effects to the group:
* Hawk Spirit (left): All players receive 500 less damage from every attack. Applied before armor.
* Eagle Spirit (right): Deals 300 damage every second to all enemies in the room.
* Falcon Spirit (back): Grants 25% movement speed increase, 25% ranged haste and 25% spell casting haste.Group makeup
* 1 Tank - Anzu does not hit particularly hard, especially with Hawk Spirit's damage reduction buff.
* 2/3 DPS - It is strongly recommended that at least one of these has AoE capabilities, but this is not required.
* 2/1 Healers - Depending on tank's and healers' gear, one to two healers may be enough. A druid healer can keep the bird spirits up during both phases, providing additional damage mitigation - while a druid tank can only keep the spirit buffs up when Anzu is banished. If a healer gets cycloned or spell bombed, it may be desirable to have an offhealer pick up the load temporarily; although, depending on gear, both effects can be safely outlived.At least one of the group members must be a Druid, since Anzu can only be summoned by using a Druid-only quest item/key. A druid may enter the instance and summon Anzu for a druid-less group, but doing so would make this encounter more difficult in the absence of statue buffs.
Strategy
The fight is a regular tank-and-spank during phase 1. If a caster is afflicted by Spell Bomb, they should STOP casting immediately; if a healer is afflicted, an offhealer, if present, should heal the party for the duration of the debuff.
As Anzu approaches 66% (and later 33%), he'll self-banish and summon birds that should be AoE'ed. It is very beneficial to keep the Eagle Spirit active during Phase 2, taking advantage of its 300 DPS room-wide AoE. You will probably find that the Eagle Spirit's AoE is more successful than any mage or druid AoE that you use. There is also the advantage that the Eagle Spirit's AoE will not draw aggro to any party member. If you have a Frost Mage in your party, have them freeze the bird flock to help avoid harm to your party members. Anzu will unbanish after 1 minute or when all birds are dead - whichever comes first. If it seems likely that the birds aren't going to die in one minute, the tank needs to pick up Anzu while the rest of the group finishes the birds off.
Generally, you'll want to keep the Hawk Spirit up as much as possible, the Eagle during phase 2 and the Falcon if you have spare time (the haste effect significantly increases the group's DPS, making the fight less time and mana consuming). Rank 1 Regrowth or Rejuvenation are basically free mana-wise, and are enough to keep the bird spirits up for 21 and 12 seconds respectively. While Regrowth is longer, Rejuvenation is instant cast - either may be used depending on the situation. The following macros enable you to cast Rejuvenation on a specific spirit without having to target it directly:
Eagle Spirit (AoE damage)...Hawk Spirit (Mitigation).........Falcon Spirit (Haste)
/target Eagle Spirit................/target Hawk Spirit.............../target Falcon Spirit
/cast Rejuvenation(Rank 1)../cast Rejuvenation(Rank 1)../cast Rejuvenation(Rank 1)
/targetlasttarget...................../targetlasttarget..................../targetlasttargetUsing macros such as the above will make this fight a lot easier than manual targeting. Manual targeting of the spirits becomes very difficult once the bird flock arrives due to the number of mobs on screen.
After the second, and last, wave of birds you may find the best way to finish the fight is to DPS Anzu down quickly.
Patch changes
The fight with Anzu has been significantly retuned in patch 2.1.2. Anzu can no longer be kited away and his Spell Bomb can be decursed:
* Heroic Mode: Anzu, the Raven God may no longer be pulled far away from the location where he is summoned.
* Heroic Mode: Anzu's Spell Bomb is now a curse and he will no longer charge.
* Heroic Mode: The quantity and health of Minions of Anzu that spawn have been reduced.
* Heroic Mode: The frequency and duration of many of his abilities have been retuned to make the fight more forgiving.Notes
* You may find it easiest to bunch together where Anzu is. It will be easier for the AoEers when the flock of birds come.
* If there's a feral druid, shift out and innervate a healer when he banishes.
* Make sure you're ready to heal the AoEers when the birds arrive.
* Try keep the left (hawk) and right (eagle) birds up at all times. Rank 1 regrowth is the best option because of the duration.
* You don't need super DPS to kill him, he has pretty low HP - just play it smart.
* If you have spell bomb on you, take that time to bandage yourself or someone who needs it.
* This boss can only be summoned by a druid who has the quest or has done it. The summoning item can be received again after completing the quest. The item goes in the keyring.[ Szerkesztve ]
Nevar
válasz -conrad- #9334 üzenetére
PvP setbonus nerf borítékolható, mivel ez pve-t nem érinti. Healingetekbe komolyabban nemhiszem, hogy bele mernének nyúlni, csak pvp-re kell némi nerf, ez meg érintené pve-t is. Talán még cyclone-t, meg rootot ugyanarra a diminishing return-re rakják, szerintem ennél többet nemigen tudnak csinálni. Inkább a palának, meg shamannak kéne vmi új képességet adni amivel életképesebbek lennének 2v2ben, 3v3ban.
Egyébként indíts egy altot BS-en, megnőne a retard resisted, aztán a "szőkecigányok" már fel se tűnnének. Vagy csak gyorsan beszereznél egy improved ignore addont
http://eu.wowarmory.com/character-sheet.xml?r=Bloodscalp&n=Nevar
Wolverine
válasz -conrad- #9336 üzenetére
Jajj Egyrészt van egy pont, ahol a feljárat van; ott elkezdve nem fogsz 6-osával pullolni Másrészt a bányában is nyúzható mobok vannak; harmadrészt szerintem a rayek is dobhatnak leathert; negyedrészt a bányában a slime-ok-ból lootolható Sludge-covered Objectben is lehet bőr nagyritkán.
-conrad-
Polacheck
HÁZIGAZDA
Polacheck
HÁZIGAZDA
Wolverine
válasz -conrad- #9455 üzenetére
Alapvetően elégedett vagyok a cuccaimmal, amíg nincs arról szó, hogy a dps túlgearelt hozzám képest; speciel most úgy éreztem, hp-ben vagyok vékony (ennyit jelent a forti meg a kings...), ha van pap, akkor 15k hp felett vagyok. (Holdbor nevére emlékszem, de nem jutottam odáig, hogy ránézzek Armoryn...)
A questrewardokkal meg az a gáz, hogy max. instarewardok hiányozhatnak még egy-két 5 fős questen kívül, mert a többit megcsináltam már
bobace
bobace
válasz -conrad- #9483 üzenetére
Túróba, ha nem sajnálnám a hordás lock altomat Ragnán, akkor én is költöznék. Ha minden jól megy a héten végre visszatérek. Addig míg tart a Darkmoon event, ki kéne váltani a két 51staminás trinketet is végre.
Nem az a szabadság, hogy azt teheted, amit akarsz, hanem, hogy nem kell megtenned, amit nem akarsz.
bobace
válasz -conrad- #9485 üzenetére
Jó lenne valahogy tartani a PH-s néppel tartani a kapcsolatot. a fránya horda, nehéz dönteni IRL haverok or PH-s arcok
Mondom a héten töltöm fel, ha jól megy, és akkor ígérem megnézem nekedNem az a szabadság, hogy azt teheted, amit akarsz, hanem, hogy nem kell megtenned, amit nem akarsz.
anulu
válasz -conrad- #9493 üzenetére
nalunk (Remorse, TN EU), mint ahogy sok mas klanban is, akik BT/Hyjalba jarnak, bossfighttol fugg, hogy mibol mennyi fer be. vannak inkabb meeele fightok (Teron, Kaz`rogal, Mother), de tobb a ranged (Azgalor, Supremus).
ranged is valtozik, attol fuggoen, h pl minden groupba kell-e imp, vagy decurse-olni kell."Jelenleg a cloud nem más mint a sales által elhazudott és eladott utópia, egy ígéret, csalánba csomagolt mézesmadzag, amit az üzemeltetés f@$zával vernek" | Feel the power! Intel Core i7 | iPhone 14Pro 256GB | iPad Pro 2017 64GB
válasz -conrad- #9509 üzenetére
ez nemteljesen igaz. 70 -en énis utáltam a warriort. azt tudni kell rola hogy nem egy médzs v lokk gearfüggö pöppet... most hogy van 33% unbuffed crit buffolva 2k ap + egy tona strength egy állat a cucc...
"Ott szimatol a sarkadban vasfogait csattogtatva, minden egyes hétköznapod: kirúzsozott medvecsapda."
steveetm
válasz -conrad- #9525 üzenetére
Maga link neve elég megtévesztő, asszem elég könnyen belátható, hogy nem a thottbot wowhead vagy allakhazam tette fel a trójait. wowdb-n se feltétlen vagy nagyobb biztonságban.
És még, ha fent is van, elég jelentős mennyiségű user error kell ahhoz, hogy trójait pakolj a gépedre.
Üdv.: steveetm -
Nevar
válasz -conrad- #9533 üzenetére
Ha a rugó stealthel akkor piercing howl, vagy demo shout, bleed effectet nem tudsz rajta fenntartani, rend az 10 rage asszem, teljesen felesleges ezt frissítgetni rajta, nekem kint sincs action baron, vagy deep wound, de ahhoz a rugót kell ütni folyamatosan ami felejtős. Ami még "pvp-skill", hogy tarsd magadon a petet 10 secig amig a healered iszik
LucifeI2
válasz -conrad- #9540 üzenetére
2 dps csapatok 5-6 mp alatt szét tudják szedni a druidát akivel játszok. Azért annyira nem könnyű.
Készülj fel arra, hogy már 1300as ratingen is mindenki full s1 és honor gearbe van, nagyon nehéz elkezdeni olyannak az arénát, aki most kezdi teljesen nulla pvp felszerelésbe. Shadow vagy Disc pap közül én a Discet választanám, melee classok elszaporodása és megerösödése miatt a Shadow Papok szinte kihaltak arénába, 2v2-be rugó+shadowpap páros ami jelenleg még igen szépen tud teljesíteni.
LucifeI2
válasz -conrad- #9544 üzenetére
Ez egy retri pala, rugó csapat volt. Nem valami sűrű csapat, de tényleg 6 mp alatt szétkapták. Perception, SoJ, HoJ, druid elhasználja a trinketet, Kidney és innentől már meghal. Én ez idő alatt pedig állítsam meg a paladint aki Bubi alatt van és a rugót akinek 90% dodge chance van, ha használja az Evasiont és a Ghostly Strikeot egyszerre.
Simán el szoktam kite-olni 2 dps-t.
Nem akarlak megbántani, de 1500 alatti ratingen azért teljesen más játszani, mint 2000es rating körül. 1700 körül lesznek olyan csapatok, akik már a CC-t teljesen kihasználják úgy, hogy mellette rendes DPS-t is tudnak tolni.
szerk.: [link] A legelső jelenetet elég megnézned, hogy tudd miről beszélek. Pont egy druidot ölnek meg.
LucifeI2
válasz -conrad- #9546 üzenetére
arenamaster helyett proximo ^^ jo a druidás macis trükk ellen értsd a resto maciba megy. hogy miért is? kiirja a talentet jah és targetelni is jo + figyelmeztet 20% hp alatt a raidwarning hanggal.
sasa311
válasz -conrad- #9530 üzenetére
Stance dance lol, egy makrót kell rá írni, amelyik warrnornak már ez se megy az hellokittyonline...
Más kaszt is figyeli a CD-it.
Warriorral pl 100x könyebb pummelezni mint egy rugóval, mert rageből egyszerűbb, mint energyből.hogy mit üssön ki és mit ne <-- ez kabaré, ugye nem gondoltad komolyan?
Miféle Dotja van a warriornak a renden kívül? (amiért kár a rage).Warrior kb noskillt igényel PVPbe, MS, hamstring, intercept, sweeping ha egybe áll a népsereg... meg legyen annyi esze, hogy ha szarba van shield + def stance + spell reflect + block.
Ezt ne hívjuk már komoly erőfeszítésnek. Egy healernek sokkal nehezbb dolga van PVP szituációba.Es mondd, a passzatszelet szemelyesen fingtad, vagy csak iranyitottal?
Luos
válasz -conrad- #9606 üzenetére
Szerintem várd meg a 2.4et, nagyon durva spirit buff jön, skálázódik majd az intellectel.
Egyenlőre ezt találtam: ((INT^(1/2))/21.45) * Spirit
te statjaiddal:
((467^0,5)/21,45)* 318 = 320 mp5
ezzel kapsz +30 mp5-tja most latom az a kérdésed hogy +18 spirit meg 10 mp5 megéri e, hát amint látod a statjaiat nezve 1 spirit 1 mp5 lesz. persze csak ha mindent jól számoltam
● Tört (tehát nem hivatalos Blizzard) szerverekkel nem foglalkozunk! Ne is próbálkozz!
● Ha új játékos vagy mindenképp ajánljuk, hogy egyszer fusd át a téma összefoglalót.
- Diablo IV
- OTP Bank topic
- Ilyen még nem volt: sztrájkba kezdtek a Samsung dolgozói
- Háztartási gépek
- Eladó konfig! Ryzen 5 5600X 512GB M.2 SSD 16GB DDR4 RTX 3060Ti 8GB!
- MacBook Pro Retina 13" M1 Chip / 16GB RAM / 2TB SSD / Magyar / 60 nap garancia
- Apple Watch S9 41mm Pink Aluminum, bontatlan
- HP 27-cr0757nz - ÚJ 27"-os FullHD All-IN-ONE PC - i7-1355U, 32GB, 1TB SSD, W11, 300nit
- Eladó Fujifilm X100T fekete
