Nézzük élőben az este folyamán érkező Xbox Games Showcase 2024-et!
gp A műsor kora este kezdődik, utána az összes trailert összegyűjtjük egy helyre.
Filléres Redmi érkezett
headhunter
Milyen "Motionflow" beállítással néztek filmet vagy TV műsort? (Sony Bravia KDL-55W829B)
Itt az első négy fokozatnál, nincs meg a 1080 soros felbontás?
...“Off”: Doesn’t apply any motion-boosting technology. Motion resolution 300 as determined via the horizontally scrolling lines pattern in Chapter 31 of the FPD Benchmark Software disc.
“True Cinema”: Ensures native 24p playback for 1080p/24 material such as Blu-ray movies. Motion resolution stays the same at 300, since there’s no MCFI/ BFI involved.
“Standard”: Pure MCFI. Doubles motion resolution to 600. Not advised.
“Smooth”: Pure MCFI with stronger intensity, which introduces more interpolation artefacts even though motion resolution did not increase beyond 600. Avoid.“Clear”: MCFI with a small component of BFI. Few interpolation artefacts with a mild decrease in on-screen luminance. Motion resolution 1080. Good for daytime general use.
“Clear Plus”: MCFI with a higher proportion of BFI. Even less interpolation artefacts, but picture is darker than “Clear“. Motion resolution 1080. Suitable for night-time general viewing.
“Impulse”: Pure BFI. Motion resolution 1080. May be too dim for most usage.A quick paragraph on [Motionflow] “Impulse“, whose black frame insertion algorithm we found to be less aggressive and more user-friendly than the [LED Motion Mode] implemented on the lower-end W705 series. The KDL50W829′s [Impulse] mode evinced less flicker and double image ghosting than the KDL42W705′s [LED Motion Mode], and we managed to extract a higher light output of 49 cd/m2 with [Backlight] and [Contrast] cranked up to “Max“. Sure, it’s still quite dim, but it’s usable for viewers who crave the clearest/ sharpest motion from an LCD...
